dear all,
I’m quite a beginner in zbrush. And I made a beginner mistake…
I’m working on a mask project (human faces which will be worn by actors). I didn’t know how to display the both sides of a single side surface (I didn’t know that in display properties, we can choose “double”). So, in order to see it, I used the panel loop and created an extremely thin thickness (like 0,001 mm…). Then I created many projects from this model. And know, I need to print this models. So I need a 2 or 3 mm thickness! Do you see how I could do it? (I don’t succeed with the panel loop)
Many thanks !
Martin
