How can I get a charp mask
Hello everyone,
how can I get a sharp mask?
in want to make 2 groups of this shirt from the UV.
Masking sharpness is limited by mesh resolution. If a mesh has enough polygons, usually a mask can be crisp enough that the uneven edges are undetectable by the naked eye.
If you’d like to cut a perfectly straight line independent of mesh density, use the SliceCurve selection brush instead to slice it into separate polygroups . This will actually slice the geometry along a perfectly straight line, leaving you with two separate polygroups that can be masked individually.
