How can I export the outlines?
I use Zbrush to edit scanned figures and afterwards sculpting it on wood. I want to know how can I export the outlines and not the hole 3d model.
I hope this helps to understand:
Thank you
Hello @Bukowski
:exclamation:Please upgrade to the most recent version of Zbrush. This is free for registered users, and obsolete versions are not officially supported.
Please explain further. Do you wish to:
  1. Export the outline ( silhouette) of the object as an image?
  2. Export the highlighted edge loop as real 3D geometry?
  3. Export the highlighted surface as 2D geometry?
  4. None of the above (please clarify).
I would like to only have the exterior silhouette line.
The option number 3, export the highlighted surface as a 2D geometry would work too!
Thank you
