Hello!
Uses UI customization.
Closing the SubPlette placed above will also close the SubPlette below. (See ①gif
way to close the SubPlette placed above, but not close the SubPlette placed below, like the default sub tool menu (see ②gif)?
The “Auto Collapse” and “one Tray Open” options in the preferences section Zber illustrates above also control how many subpalettes can be open at once. Adjust these to keep more than one open at a time.
Remember that you have to store config (preferences > config > store config) to have changes to the preferences persist at each startup.
Thanks for suggesting a solution immediately!
I tried but it did n’t change
And sorry!!I just realised,At first I said “Sub pallet”,The main theme of the theme I wanted to solve was “UI Groups”! Maybe
Apparently, “AutoClose UI Groups” in “UI Groups” seems to have a direct effect on how to close
So if it’s possible to turn off “AutoClose UI Groups” in ”Costom UI”, it seems to be a solution.
However, the default tool displays an orange circle mark of the UI group,
Since it is not displayed in Costom UI, it may be impossible to perform the same operation.
At the top is “CustomUI”
The settings for “Palettes” and “UI Groups” do not seem to be reflected in “Costom UI”.
The orange mark of “UI Groups” displayed in the default Tool is not displayed in “Costom UI”
As a solution to the specification that the order of subpalettes cannot be changed because there are many genres not used in subpalettes in tools, we tried to reproduce only frequently used subpalettes with “Costom UI”.
umm …
