Can zbrush brushes be made using programming? How are the brushes that come with zbrush without alpha made?
You cannot make ZBrush brushes using programming. You can modify existing brushes within ZBrush and save them as new brushes but you can only use the options that are available within ZBrush.
Thank you for your answer, is it because zbrush’s pen is not open source?
Yes, that’s right. ZBrush is not open source software and doesn’t have an SDK. ZScript is the only way you can extend what the program provides.
thank you very much
Learning zbrush script programming is there a tutorial to learn
The best information is in the online documentation here:
http://docs.pixologic.com/user-guide/customizing-zbrush/zscripting/
With the Command Reference here:
http://docs.pixologic.com/user-guide/customizing-zbrush/zscripting/command-reference/
HTH,
Marcus
Thank you for your guidance
