just a noob question.
Is there a way to change the hotkeys for brush size etc?
Or will this come in a new hotkey editor for Z3
I use the left and right bracket keys to change the size. I click alt on the brush I want and then choose a keyboard shortcut for them.
In the Zplugin palette you will find the buttons that actually do the brush size incrementation. Ctrl+Click on one, then without moving the cursor off the button press the key you want. Press Enter, then do the other. When done, save your hotkeys through the Preferences palette.
I never tried that but that could work too but I believe by default the left and right brackets control brush size also if you have a pen tablet you can click and hold and change the brush size as well. If anything you can set the touch area on the wacom tablet to control the brush size going up and down
Using the bracket keys to resize the brush works great on a PC but does not work on a Mac. Does anyone know if there is a way to do the same thing on a mac or what the Mac hotkeys would be for controling the brush size (other than the “s” key) If I wanted to do it via a slider I may as well just go up to the top of the window and do it there.
Thank You.
UPDATE: nevermind. I searched a little more and found the answer I needed. I should have searched a little harder in the first place. Thanks anyway.
Wow, 3 year thread Necro
