Hotkey not storing
Hey guys, I have a problem where my set hotkey for my custom menu doesn’t store. Or better said, doesn’t work after restarting ZBrush.
I have other keybinds that work without a problem, and I know how to Save / Store hotkeys.
It’s a minor issue having to keybind this menu every time I start but it would be nice if it got resolved.
Hope someone can help me here.
Greetings Manoj
Hi @Rachquiat,
it would be helpful to know which hotkeys do not works in that case, can you tell us more ?
Best regards,
Nicolas
Thanks for your response,
I’ve set my custom menu to the hotkey ‘K’
But i have also tried to remap the ‘N’ key.
It all works fine at first.
Storing and saving the hotkeys aren’t giving me any errors.
its just that after a restart it seems to be gone, while my other hotkeys are remembered
Hello @Rachquiat ,
I’m not having any problems saving either hotkeys assigned to K or N, or a custom menu assigned to those keys, and having it persist after a restart.
There may be an issue with the custom menu itself, or some function you have assigned to it. Are you able to assign this menu to any key and have it persist after a startup? We may need to take a closer look at that menu.
Likewise, are you able to assign any other function to those keys, and have it persist? Something simple like Polyframe mode? There may also be some aspect to your installation environment that is causing a problem.
Here is a video illustrating the creation of a custom menu, and the assignment to a hotkey.
If the video doesnt help you resolve your issue, you will need to contact Pixologic Support for us to take a closer look at your problem.
Thank you!
Thank you for your response spyndel, i will re-install zbrush. and otherwise i will contact the pixologic team.
have a great day!
