Hi
Is it possible to setup SelectRect brush to SelectLasso state?
I know these both brushes have the same base type (HideShow) and I can change Stroke in SelectRect brush to lasso type, but I don’t know how to enable poly and edge highlighting which SelectLasso has and how to activate HideEdgeLoop function. Where are these brush options in UI? I showed what I mean on screenshots
Try using SelectLasso brush with a Rectangle stroke if you want Rectangle functionality and still retain Edge and Poly selection. That’s probably the only option.
