Hide & show mesh without symetry but still using symetry!?
I realise the title doesn’t make sense but basically what I want to do is select one leg in my mesh to work on whilst hiding the other + the rest of the model but still have symmetry enabled to work on both legs at once. It’s just difficult to work on the legs when they are together.
I’m a noob so any help will be greatly appreciated.
Can’t do it.
What you can do is work on one leg then use smart resym to bring back the symmetry on the other leg.
Or you could simply sculpt one side of your model and then use Tool>Geometry>Modify Topology>Mirror And Weld.
Thanks that’s dissapointing but guess it’s as good as.
