hide command
trying to modifiy some macro’s i made.
is there a command to unhide a partially hidden mesh, and if necessary to rehide those polygroups again?
You can use Tool>Visibility>ShowPt to show the whole mesh but there’s no way to select polygroups so that they can be hidden again. You can hide points that aren’t masked using the Tool>Visibility>HidePt button, so if you can mask by alpha that may suit your purpose.
slaps forehead!
show pts will work for what i want, i can deal with the other issue, thanks again!
