Hi there, I’m a newbie to Zbrush. I’m having a problem. When I hide the mesh by holding down Ctr + alt, it will hide the mesh fine, but when I do the same thing not over the mesh, just in blank space it will show the other part of the mesh that is unhidden. It will simply toggle back and forth between the two and I can never get my full mesh back. What am I doing wrong? Thanks for your help.
It sounds like you are dragging the mouse slightly when you CTRL + Shift click. Take a look at the Help script under Modeling 3D Objects > Partial Mesh Visibility for a list of CTRL + Shift actions and a zscript tutorial.
If you are still having trouble getting it to work you can use Tool > Masking > ShowPt (Show Points) instead. Although intended for masking operations it is fine to use it in this case.
