Help! Zadjustor no longer works in 2019.1 looking for User Keupon!
Hi, my most used script Zadjustor (allows you to adjust brush size like photoshop) no longer works in 2019.1. I seriously can’t live without it (hate the way zbrush does brush size with the S key!). Does anyone know how to get ahold of Keupon, who wrote the script years ago?
thanks!
bumping this threat. is there a version that works with zbrush 2021.7.1 ?
i can see there should be an adjust plugin from pixologic as i can see in the ressource section but i dont find it in plugin menu. also in installation it doesn’t show up. is this not being shipped with zbrush 2021 anymore?
The Adjust plugin was removed because there is now similar behaviour in ZBrush:
If you turn on Preferences>Interface>Click>Use Sticky Keys you will be able to set any slider by holding its hotkey and moving the cursor. So, for example, holding ‘S’ will allow you to set the Draw Size by moving the mouse from side to side. If you want to use this option remember to store the configuration (Shift+Ctrl+i).
Additionally you can use the [ and ] keys to set the Draw Size up or down by increments. The value can be set in the Zplugin>Misc Utilities>Brush Increment slider.
HTH,
Marcus
