Hello,
I’m unfamiliar with Zscripting and couldn’t find an answer googling around. I have about 200 .STL files in a folder that I would like to:
- open the file in Zbrush
- run the following macro
- export into a specific folder
Here is the macro that I saved:
//ZBRUSH MACRO - Recorded in ZBrush version 2021
[IButton,???,“Press to run this macro. Macros can be aborted by pressing the ëescí key.”,
[IShowActions,0]
[IConfig,2021]
[FileNameSetNext,“C:\Users\JakeShearer\Dropbox (ToLTech)\R&D\XR\Ojemann-Thompson Project\Case11\Freesurfer_STL\case11_objects00012.stl”][IPress,Tool:Import]
[IConfig,2021]
[IConfig,2021]
[FileNameSetNext,“C:\Users\Public\Documents\ZBrushData2021\ZPluginData\3DPrintHubData//ascii.GoZ”][IPress,Tool:Import]
[IPress,Tool:SubTool:Rename]
[CanvasStroke,(ZObjStrokeV02n45=H348V281H34AV281H384V283H39AV283H3BBV284H40AV286H43AV286H486V286H4CDV286H4F3V286H516V285H52FV284H53EV282H550V281H55CV281H566V280H571V27EH579V27CH587V279H595V276H59FV274H5A5V273H5A6V273H5ABV272H5ADV271H5AFV270H5B0V270H5B4V26FH5B7V26FH5BCV26EH5CCV26DH5D6V26AH5DBV269H5DFV268H5E0V267H5E2V267H5E3V267H5ECV266H600V266H618V265H627V263H63DV261H64CV25FH653V25DH653V25D)]
[IPress,Transform: Edit]
[IPress,Tool:Geometry:Half]
[IUnPress,Tool:Geometry:Adapt]
[ISet,Tool:Geometry:AdaptiveSize,100]
[FileNameSetNext,“C:\Users\Public\Documents/ZBrushData2021/Temp/objIn.goz”][IPress,Tool:Geometry:ZRemesher]
[IPress,Tool:Geometry:Close Holes]
[IPress,Tool:Geometry:WeldPoints]
[IPress,Tool:Geometry:Optimize Points Order]
[IPress,Tool:Geometry:Check Mesh Integrity]
[IPress,Tool:Geometry:Fix Mesh]
[FileNameSetNext,“C:\Users\JakeShearer\Dropbox (ToLTech)\R&D\XR\Ojemann-Thompson Project\Case11\Freesurfer_STL\Case11 OBJ\case11_objects00012.obj”][FileNameSetNext,“C:\Users\JakeShearer\Dropbox (ToLTech)\R&D\XR\Ojemann-Thompson Project\Case11\Freesurfer_STL\Case11 OBJ\case11_objects00012.obj”][IPress,Tool:Export]
Thank you in advance for any help, I don’t really know where to begin!
