Help with Model in Zbrush
I created this model in another program ( one possible use is for a mermaid) and imported into Zbrush Z2 and begin looking over the model and want to clean it up. So I did poly div two or three times then got a Zbrush message that said I would have to change the mem setting in pref>mem so I changed the default (.87 I think) to 10 and had to do an exit from Zbrush as I don’t think I have enough memory in the cpu to do the 10. Anyway, I would like to clean up the model (smooth, etc) so that it takes textures better. I tried the Def>Smooth several times and after that it did not look like it was smoothing the model anymore. I tried the poly div twice and it looked like it was cleaning up the model.
