Hello I’m hoping someone can help me out.
I have been using ZBrush on and off as a hobbyist for the past year or so with no problems, but I am well aware there is a lot about ZBrush that I don’t know/use.
Enough background…
The problem I am experiencing seems to be two fold:
that brushes are only effecting the mesh at about 20% the diameter of brush size setting (red circle), even taking in to account the focal shift.
that the intensity of the brushes is also considerable reduced, I have checked the intensity slider. Even the mask pen at 100% intensity is only operating at greatly reduced percentage maybe 25%
I don’t know if I have done enough to describe the problem, but in short it is as if all drawing operations are at a reduced size and intensity compared to the settings and their visual representation i.e. red/yellow/blur cursors.
I have gone through all the various settings looking for things that could be causing this, but all the obvious things seem to be set correctly. I have also tried re-initializing ZBrush (Prefs menu), this has also proved unsuccessful.
The problem manifested itself on 4R6, in an attempt to fix this I have updated to 4R6 p2.
Hopefully there is an obvious answer, as this is preventing me from working.
Thanks in advance.
C.
