Hi folks, I am attempting to prepare a picture for printing by an outside source. The image is for a calendar and I am running into some problems.
I am having a little
problem with with dpi resolution v.s. height & width in inches. I will try
an explain it hopefully so that it makes some sense.
Firstly I am using Photoshop to save the image. The size of the image needs
to be 12.5 in. by 12.5 in. finished physical size, and the dpi resolution
needs to be 350 or better in .tif format.
OK so I created the image in Zbrush to be
1800 pixels by 1800 pixels so that when I took it down to AAhalf, it would
be 900 by 900 which is 12.5 by 12.5 inches at 72dpi. When I increase the
resolution to 350dpi the image enlarges to 4375 x 4375 pixels but still says
width & height are 12.5 x 12.5 inc. Yet the image on the screen is at least
double those physical dimensions. When I put the ruler on to measure it
looks like each inch shown on the ruler is actually 2 inches in real size.
And of course the image is not sharp and certainly not acceptable because
now it is oversized!
How can I overcome this? I can’t do the original in 4375 x 4375 pixels
because Zbrush won’t produce a document that large.
Any help with this would be greatly appreciated.
Thanks
Donna
