I’m fairly new to Zbrush and I often encounter random features by accidentally pressing keys on my keyboard while sculpting. Does anyone know why are there lines on the 3d model and how I can remove them?
Hi @LP_Baez!
Does Ctrl-Z not undo this? It looks like you may have Framed your Polygroups with Curves (7 on the keyboard by default). Curves can be deleted via Stroke > Curve Functions> Delete.
But Ctrl-Z should undo most accidental actions, unless that action actually switches you away from your active subtool. In that case you would have to make the subtool active again to regain access to its undo history.
Stroke / Curve Function / Delete did the trick. Thank you!
