Hi everyone,
I found a free preview lecture on uartsy.com on Hard Surface Sculpting with Tom Paul but i run into trouble when i try to do what he shows here: http://www.uartsy.com/content-preview/node/12080
At roughly 4minutes10seconds he uses the clipcurve to cut out some indents and it’s superclean and straight. When i try to do this, i allways end up with angles other then 90 degrees.
To draw with the clipcurve i just start drawing from top to bottom, click alt twice to get a sharp corner, go to the right, click alt twice again and move up again but clearly this is not the right way.
Dynamesh is same res he uses, symmetry is on for x and y as well.
I tried to use the cliprect but that doesn’t work at all for this case.
I could use some help here as i would love to go out and buy this whole course but i’m afraid it’s a bit too much for me just yet.
Thanks.
