Help- merging two object in zbrush
Hi guys,
I have recently start learning zbrush, and the first thing i did in my practice is to use a polysphere from zbrush to build a head… now the problem comes when i am trying to build a neck for my model with another polysphere.
i can’t seem to merge those two objects into one mesh since both of the spheres are sealed, i just can’t paint or adjust the area where the neck and head meets without making the crease visible…
i tried to delete the bottom part of my head and upper part of the neck and merge then, but what i would get are alot of holes and gaps in between
anyone know an easier way to merge two objects?
thx…
use subtool master. then click merge and follow instruction
but since both of my spheres are sealed without openings, the subtool master will only turn those two objects into one, but a seam line will appear when i want to smooth the connecting area between two meshes.
click creases button in tool>geometry rollout… then divide
Could you explain more noobvee? I tried your instruction and the seam is still there.
