Help me find a right graphic or pen tablet
currently i can get these tablets. I don’t know which one is better (please click on the link for info) for zbrush
monitor resolution 1920X1080 (16:9)
OS: windows 7 profesional (x64)
RAM : 8GB DDR3
Graphic card :SAPPHIRE HD 7770 GHz Edition 1GB GDDR5
Genius Easypen i405 Graphic Tablet
[iBall Pen Tablet 5540U](http://www.snapdeal.com/product/iball-pen-tablet-5540u/34475?pos=15;56#Technical Specifications)
Genius MousePen i608 Tablet
[Bamboo One Home 4x6 inch Tablet](http://www.snapdeal.com/product/bamboo-one-home-4x6-inch/224739?pos=19;56#Technical Specifications)
[iBall Pen Tablet 8060U](http://www.snapdeal.com/product/iball-pen-tablet-8060u/34476?pos=20;56#Technical Specifications)
Genius MousePen M508 Tablet
Wacom One By CTL-471/K0-C 8.26 x 0.29 inch
Wacom One By CTL-671/K0-C 10.9 x 0.29 inch
I allways used Wacom. Never fail to me. I´ve been using Intuos 3 large but didn´t like big tablets, so i moved to a simple bamboo one. Worked just perfect to me during 3 years.
I´d recommend this one if you can, or the touch version for multitouch gestures, it´s up to you
http://www.snapdeal.com/product/wacomintuos-pen-only/1435626295
Thank you so much for your help,
Is there any major advantage with the multi touch ? since I’m a beginner I thought I should go with the one from the last two there are also from the wacom, and what is the difference between the one you said from the last two ?
Both you suggest are older Bamboo series. The one i suggested is the lowest quality of Intuos series, witch is a higher serie. But there is no differences at all when you draw on them. 1024 levels of pressure is more than good to create the best artwork piece.
The difference between your choosen ones is just the size. If you like it Small or Medium. (I use small because i don´t like long strokes when modelling or painting, Zomm in and out do the rest.)
The wacom i suggested is not multitouch but you have same model with multitouch. It´s just extra feature you can find handy if set as zoom and rotate in Photoshop etc…
If want to see in depth more comparison between those wacoms here is a nice video explaning.
http://www.youtube.com/watch?v=VRPYN4dS0xU
My conclusion is: Intuos line is newer and has better design but the Bamboos has same functionality for less price. Personaly i don´t like the feeling of the bamboos surface. It´s too rought. Newer wacoms are a bit smoother.
Any case. I´ve been teaching and installing docens of wacoms bamboo, intuos for years and i never saw a wacom failing. No matter the series no matter the version all wacoms are just perfect
OK one last question, I red some where that the monitor resolution ratio and tablet active are should be some what proportionate so if I chose one with the 5.98 inch X 3.74 inch does it work well with my 16:9 resolution monitor ?
All wacoms have preferences to set up. You can scale proportional to your monitor. Use one or both in same space or unconstrain proportions and draw your own working space.
FYI. I recived an Intuos Small Pen and Touch. I´m just like a kid with new shoes. Fits perfectly with my spectations for a low wacom series. The touch pad feature it´s the best of all. I can now navigate and go through 2 monitors with my finger and then just continue sculpting with the pen. All working smooth and intuitive. It´s awesome price/quality ratio IMHO
thanks to you I can finally make a decision thank you so much :slight_smile:
Glad to help!
Also new Intuos has some Express key configurations that i do really love. The radial button, Keyboard, and navigation gestures are really handy. All customizable as you want. If you buy the wireless kit you can use as remote control of your Pc :cool: To me small size it´s the most comfortable.
Wish you all the best and would like to see some of your Zbrush artworks soon!
thank you I’ll do my best,is it OK if I use any micro USB to USB cable because the cable the provided is pretty short,does the affects devices performance by any chance?.I though of buying a USB hub but after a bit of research I found out it could be a bad idea, any thought ?
I can’t warranty any mini USB would work on every wacom. But I tested my new intuos with my phone cable and it works perfectly normal.
