Help making neon tube design
Hi, I am trying to make a neon sign with quite an intricate design. How would you suggest I do this? I could use thin cylinders and “bend curve” them to shape, but I think it would be incredibly time consuming. The initial design will be in illustrator, so is there a way on converting SVG lines or shapes into tubes?
Thanks, Rob
Hello @robertjamesgibbs
You can open SVG files with the “Text 3D & Vector Shapes” plugin in the plugin palette. A combination of that and the “Frame Mesh” video below should give you some ideas.
Thank You!
