so im not sure where the option is for this but its stumping me… i want to be able to drag out the repeating pattern when i use the stroke with the curve but it keeps overlapping like so… ideas? (see images) Thanks!
To define the distance between each inserted mesh, use the Stroke >> Curve Step slider. A value of 1 will touch each inserted mesh to its predecessor. Lower values will cause the inserted meshes to overlap while higher values will separate them from each other.
