I hope some one can tell me what I’m doing wrong here. I want to create a background image for use with lightcaps. I have cropped an image so that is has a ratio of 2:1 and made it the same height as the document. I create a new background in the lights menu, then import the image. Each time I import it, the image is much bigger than the document, despite having the same height. No matter how small I make the image it is always much bigger than the document. Also, in the ZBrush documentation it says you should press the camera button in the transform menu to snap the image to the document, but my camera button is always greyed out. Can anyone help with this, please?
