I load the zscript but nothing happens…why??
I expect you can’t see the button because the Tutorial Window is closed. First load the zscript using the ZScript:Load button. Then press ‘H’ on the keyboard or drag the handles at the bottom of the ZBrush UI to open the Tutorial Window. The zscript Play button should then be visible.
Thanks…!
