when i press a ‘a’ and enable HD geometry, everything is going smooth until i clicked quick save. the HD geometry automatically disable and i lost my mograph target. whats the problem here?
Hello @Skillerdose
I tried to replicate the quick save thing, did drop me out of HD mode and I lost my morph target from HD mode, but I also stored a morph target before I went into HD mode and it kept it.
I think its really bad idea to save your zbrush file while you are in HD mode, it increased the file size by a lot you quick save folder will end up taking up a lot of file space on your hard drive. In Kris Costa’s fly on the wall class he had us set the quick saves to be less frequent to avoid that issue.
If you save your file with HD mode not active the file size will be much smaller, but you will still be able to go back into HD mode. Losing the morph target kind of sucks, guess you got to make sure you get all the changes in while your in HD before you leave it. Also set the quick save max duration a bit higher and delete the quick save folder every now and then. There a setting in the preferences for that under quicksave.
oh thank you. i thought it was a bug.
