Half of ZBrush off screen
This is a weird one. If I start up ZBrush then click on another window while it ZBrush is loading up half of ZBrush window ends up of the right side of my monitor.
If I just do nothing then the windows loads up fine. I can still move the window vertically but not horizontally to bring it back on screen.
Only ZBrush does this. It’s not a huge problem but still very strange, also I havn’t learned to wait until it fully loads up yet but I will, eventually.
I’m on PC using Vista
I have the same issue, Im always careful not to do anything else while ZB 3.5 is loading. If I screw it up though, usually I can just drag up top near the title bar, and my cursor goes to the arrow-cross move icon, and I can drag the program back into window. Everything is fine if I just restart it. On vista here too.
Changing the display resolution forces ZBrush to recalculate its position, which it then remembers going forward. If ZBrush consistently loads in the wrong place, try the following:
  1. Change your display resolution.
  2. Launch ZBrush. It should be right now.
  3. Close ZBrush and change your display setting back.
  4. ZBrush should still be right.
Thanks aurick that seems to have sorted it out.
