Hello,
I am pretty new with ZBrush. I was sculpting the Spongebob Character and I started painting it when “I did something and I do not know what” and I exited edit mode and drew a copy of my model which appeared flat gray(see attached image) when I cleared the document using Ctrl+N my old painted model disappeared and only the new flat gray model is left. Also there when I move the model only at a certain region I can see the model with redwax material, and in the subtool menu my subtools are painted like they should be. I hope someone can help me!
Many Thanks
You should upgrade. Read a bit more and be careful with your keyboard and mouse
- Turn off Edit mode.
- Make sure Z Intensity and RGB Intensity are both set to 100.
- Turn on Edit mode again.
