Grabdoc and document size
Im trying to make my Grabdoc size same size as my Document size( where object/mesh is). But when i bring in the texture in spotlight its not the same size as my mesh in documant. My Grabdoc is smaller then my Mesh. So i have to keep scaling the grabdoc bigger in spotlight. can anyone help? ty:)
Which version of ZBrush are you using?
Which button are you using?
If you’re using Texture >> GrabDoc or Texture >> GrabDocAndDepth the results should be the same dimensions as your total canvas (Document Size).
Is there the possibility that the document size is larger than the visible area on your screen?
