GOZ switching default application.
Hi. I just updated the goz install for photoshop. Cool by the way. But I also have max. The first time i ran goz it asked which app I wanted to use. Ichose PS and it worked as advertised. Now however I can’t get it to send anything to max. I’ve updated paths, forced reinstall etc. But every time I hit the goz button it just goes to PS. Where can i change this?
I’ve looked and searched and I could only find this and it didn’t help:
Q: When clicking on the GoZ button, GoZ isn’t launching the correct application. How can I fix that?
A: In the ZBrush Preferences >> GoZ menu, click on Update path to [your application], then select from the applications found by ZBrush or if ZBrush can’t find the application by itself click on the Browse button and select the application’s executable file. To avoid potential issues after this step, click on the Force Reinstall button (also found in the GoZ Preferences) and select your application.
Thanks
Try this-
http://www.zbrushcentral.com/showthread.php?p=835802&posted=1#post835802
Thanks for the heads up. I’ll give it try.
