GoZ Support for Cinema 4d R14
My Zbrush version is 4r4, does Goz supports Cinema 4d r14?
I ask that cause my Goz is behaving fun, since i had cinema 4d r13 no problem, every thing was fine. I update my cinema 4d to r14, i manual install Goz file to Cinema 4d Directory as i did for previuos version, if i want send a tool from Cinema to Zbrush no problem, if i want send from Zbrush back to cinema i recall goz setting (my goz default application is max), in the list cinema 4d is greyed out as it was not installed in the system.
Any suggestions please?
Sorry about my beginner question
Thank a lot!
First off, why haven’t you upgraded to 4R5?
Hi!
in my case it works exactly the other way around:
ZBrush 4R5 -> C4DR14 is no Problem but if I want to send the changed mesh back to ZBrush,
the mesh changes in C4D to the state when it came from ZBrush.
Any idea what’s going wrong here?
THX!
Thanks a lot,
it is 5 months that i dont open zbrush and my pc generally speaking,
unfortunately i had to spend long time at Hospital, i did not even know there was r5 update.
Anyway goz works fine between cinema r13 and zbrush r4-r5, the problem seems to be between zbrush 4r4 and cinema r14, i can send fron Cinema to Zbrush, no prob at all, everything works fine, it dont work from Zbrush back to Cinema, the cinema 4d voice in goz setting is greyed out, as cinema was not installed in the system.
By the way i’m n windows 7 64 bit
