GoZ -> Modo broken after 401 update
Luxology has released a path for 401. Now GoZ is not working any longer…
Fix soon?
Rainer
Simply re-install GoZ to your updated Modo and you will GoZ to&from Modo in no time:)
Also, see the first post in http://www.zbrushcentral.com/zbc/showthread.php?t=72585
I find this GOZ thing confusing.
I use Modo and Zbrush, I have latest versions of both. I can not import any GOZ file in Modo, but I can export from Zbrush, but there is no GOZ button anywhere in Zbrush.
Is this currently only working on Mac versions?
https://support.pixologic.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=18&nav=0,13
However, if you have Maya, you can export .ma files now, which will have all the data in one file. From what I understand, the functionality is there in ZBrush already, just not in the other apps yet. That’s what they’re working on.
Thanks for the link and clear-up, James.
Whenever it’s coming I’m thinking it’ll be worth the wait, looks like it’ll be a huge timesaver.
