GoZ install issues
Hello!
I upgraded to 2019 and zbrush seems to be running well. My issue is with GoZ, I can update the app paths but nothing connects to zbrush. (Lightwave, DazStudio, Poser, Vue)
Also, when I try to use GoZ to export to an app I get an error, it’s looking for a script in public/pixologic/gozbrush/scripts/goz_exportfromzbrush. The directory and the script do not exist. It look between the install and uninstall of 2018 something failed.
Do I need to deactivate / reinstall 2019 or is there a plan b?
Thanks,
Bill Carey
In the main ZBrush 2019 folder there is a folder called Troubleshoot Help. Close ZBrush and then run the file called GoZ_for_ZBrush_Installer_WIN.exe. This will recreate the folders needed for GoZ to run. However, for the applications you mention (such as DAZ Studio) Pixologic is not responsible for GoZ - you will need to reinstall GoZ from those companies.
Perfect, thank you!
