GoZ for Houdini, the one the comes with SideFX Labs, doesn’t export/import creasing information. Is this data that the GoZ file format contains? How do I gain access to the GoZ SDK. I’m trying to figure out the best way to get creasing from ZBrush into Houdini and so far I’ve had no luck. I know FBX exports crease data but Houdini stores crease values as Polygon Vertex Data, not edge data. I could parse to FBX file and translate the information, but I can’t even automate exporting and importing FBX with zscript. And also ZBrush does this thing where when you import an FBX file it creates a new tool Any helps would be appreciated. Thanks!
