Hi I am getting this error when I install Goz for Modo on the mac. Anyone know how to fix this?
Is this when you click the GoZ button under Tools or when you click on the GoZ path to Modo options in Preferences?
Before you click the GoZ button under tools you need to let Zbrush know where the Modo App is located. This is done under Preferences > GoZ > path to Modo button. Click on this and it will try to automatically find Modo. If it doesn’t find the correct location you can browse and select the app. After that it should work.
Its really strange because this is the message that I am getting after browsing and choosing the path to the app. It is happening with all the machines in the class room also. I am mainly a Win user and haven’t had any problems with that side so I thought it might be a common problem with the mac? I also tied a manual install and no luck.
You sure the modo.app actually exists in your Applications folder?
It could also be a permissions issue.
