Updated to ZBrush 4r6 and things went a bit wonky with GoZ and Modo 401. Everything was working fine before the update, but now I can only send models from Modo 401 to ZBrush via GoZ. When attempting to send them back to Modo 401 nothing is updated. I’m on Windows Vista 64 bit (eek, I know). If trying to send a model originating in ZBrush over to Modo 401 nothing is sent at all. I’ve already tried reinstalling Modo 401 (sp5), manually replacing the GoZ files and praying to the Gods but nothing works. Is anyone else having this problem or perhaps knows how to fix? Thanks in advance.
Tried deactivating and uninstalling 4R5 and 4R6 to start from scratch with the standalone 4R6 installer. Behavior is still the same. Files can go from Modo to ZBrush but not the other way around. Even tried with antivirus completely disabled. Yep, need help please
D’oh! Um, nevermind. Problem was user error (PEBKAC). Forgot to run ZBrush as administrator. All is good.
