Made this goblet mainly to play around with transparency in the render property’s.
In the render filters “fade” helped to look more glassy.
That’s a Zbrush render ?? !
small_orange_diamond
look very nice, try to experiment with refractions also
Looks great! Havent seen bpr render like this before.
Hi guys,
Yes rendered in Zbrush, Here are my settings. In bpr filters used Fade, Glow and additive.
All I did in PS was add those tiny sparkles on the right side of the cup.
Found a way to have my back ground render without disapearing which makes it easier to tweek. Cheers!
What material are you using?
great work, what about to see the trasparency on a single subtool? I’ve made this question on my thread but seems a limit of zbrush…see my post #1637 , link: http://www.zbrushcentral.com/showthread.php?170297-Artworks-amp-WIP/page110&p=1074932&infinite=1#post1074932
i mean to look on the hidden part of a single object. I can’t render this.
Hi Doug, I made the material myself. Used a photo of a glass marble from a spray can. Let me know if you want to know more. Cheers.
great stuff … can we have a look at that material dude…!
I downloaded “Green Glass” from Zbrush download centre. Then tweeked…see my settings.
I make a lot of my own by importing a cropped image similar…works great!
Hi, Built up this image in zbrush with bpr render and snap shoting it to panorana. Touched up in ps but mostly done in Zbrush.
Thanks Goblet,
I have been looking for a SIMPLE tutorial/way to create translucent/glass effects for my jellyfish characters. This is perfect. But my material dose not seem to have the transparency in effect? what have i missed?
also im interested in a another simple tutorial like this on how you work with PHOTOSHOP to create your materials
