Gizmo3D Scale X Orientation
Hi guys. Just noticed that clip function of scale manipulator do not work properly if we change X manipulator direction from left to right side.
Here is custom gizmo i use. And if you try to CTRL + LMB DRAG on red scale manipulator you will see that it work in wrong direction compared to other scale manipulators.
I suppose this interaction somehow convert distance between current position and gizmo center position to clipping value. I guess this issue can be solved ez.
CUSTOM_GIZMO3D
Hi @Prostrelov
I can’t duplicate this with the default manipulator. Ctrl-dragging in one direction clips from one direction, dragging in the other clips it from the other direction. Rotating the gizmo to face the other direction on the axis does not change this.
If using a custom manipulator, I would look to that for the issue. Always remove custom content when trying to troubleshoot an issue, to eliminate variables.
Yes. It’s not a default left oriented gizmo issue.
Its issue with interaction formula for clipping.
Just mention this here for next Zbrush revision.
I had similar problem with interaction formulas due developing plugins for softimage and maya.
I guess Gizmo3d is one of development priority and this small issue can be easily fixed.
