Do I need to hit the accept button after performing a tweak or can I just hit the draw button to get out and carry on.
Hello @jimmylegs,
In most situations either works. For certain multi-part deformer operations you may wish to hit “accept” as an intermediate stage before performing further operations with the deformer.
Ok thanks for the reply. I have noticed sometimes I have to reopen the dialog box and hit accept to continue otherwise weird things start to happen.
Well, you will need to exit the Deformer mode before you can use the normal Move mode again. You need to switch back to "Gizmo3D " in the Deformer menu.
I just meant in order to continue to deform the mesh. It seems that every once in while you need to hit accept to lock in what you have done and then continue deforming.
