Like the title says. I can move and edit tools, but there is a huge picture of a tool blocking my view. How can I fix this? I’ve tried init Zbrush, reopening, reopening the .zpr’s(I have 2 of this same file) and I don’t know what to do. Other zpr’s work just fine.
At some point you probably made a snapshot of the model. This makes a pixol copy of it – one of ZBrush’s 2.5D painting features. You might have saved as a ZBR (Document format) or you might have accidentally pressed the shortcut to Snapshot (Shift+S). Either way, you should be able to just press Ctrl+N to clear all pixols from the canvas, leaving you with just the model that’s currently in Edit mode.
