Hello guys
i can’t get the condition from iswitch , for example i want to know when it is pressed or not .
igetstatus not work i tried with all IGet commands but there is no return
Thank you for the help
Hello guys
Hey You need to use the IGet command followed with the button path for example:
[VarSet, i ,[IGet, Draw:Camera]]
[Note, i]
If it’s turned on you get a value of 1 if it’s turned off a value of 0 so then we can use the variable i to do an action for example:
[If, i == 0,
[ISet, Draw:Camera, 1]
This will turn it on
Thank you so much !
