Getting GoZ running
I am a bit confused about getting GoZ running…
Modo 4.01 (Latest new install 64bit)
The modo install will not work as I run a 64bit version in a a custom dir. So the install tells me to do it manually…
Anyway… there are a few problems…
  1. There IS no extra3 directory in my modo install. There is a extra directory. Do I place the file in extra or make a new directory called extra3?
  2. There IS no GoZ_KeyShortcut.cfg file in the modo GoZ install directory… where do I find this file?
Max 2011 64BIT
When I try to do the install it asks me for a exe file… Is this “3dsmax.exe” ?
Also I run 2011 and 64bit… is there anything I need to do like in the modo install as max is also not in a default program files directory?
Thanks in advance
