The script below is little more than a proof of concept, but it could be used to enable ‘gestures’ to be used to make adjustments to tools deformation (eg. offset).
It’s based on the crop tool code by marcus_civus which was itself influenced by Svengali’s crop routine.
If you are curious, please look over the following script and try it out. It’s not finished, and probably never will be, but if you know what you’re doing and you want fiddle or adapt it into something super, you know what to do.
Thanks for the source code.
