Ganesha Ashok Binayak
Concept and Element Design
From the meaning of wind I often think of clouds with a breeze blowing through them. Until it becomes various shapes and symbols That conveys the meaning of nature and the wind that I insert into my work.
Various angles
This is excellence!!
Thank you. :smiling_face_with_three_hearts:
Concept and Symbol of Ganesha Ashok Binayak.
Designing for me starts with solving problems. For example, the Thai pattern on the back of the starting point is a result of solving the problem of “weight bearing” because this will be the first work that is larger than 15 inches. The fabric that supports the weight in one place, I think, will have a problem. Therefore, the scene was designed for this purpose. and add symbols Nature and “infinity” conceal auspiciousness to the work.
After considering for a while and print out the work to see So I decided Modify the facial structure slightly to make it more expressive.
gradually developed Until it’s perfect
Beautiful sculpt!
Thank you.
Coin type, size 4.2 cm.
Amazing work man!
Thank you.
4.7cm
The work is currently being created in a 23-inch size, cast in bronze.
Exhibited at the “It’s Art” exhibition at The Paseo Park, Kanchanaphisek, Thailand.
