Im trying to load in a font that I downloaded but Zbrush won’t load in any new fonts. the file is a ttf and I’m clicking load from disk but when I select the file the window closes but nothing happens. Ive heard this was a bug for Mac but apparently the issue was supposed to be fixed in an update which I am a version past. Does anyone have a solution to this?
Hi @Wulfkyn ,
There were some issues corrected in the 3D text plugin, so please be sure your version of ZBrush is fully up to date.
However, I can verify a problem on MacOS with the loading of non-standard (not installed on the OS by default) through the plugin in ZBrush 2023.1.1. There is no issue on Windows.
I’m going to forward this to the Development team for attention.
Thank you!
Thanks for the response. I am up to date. Hopefully a fix is on the way.
