So I have a model that I want to print but it has flipped normals in the model so when I made the tool and imported the model I cant find how to flip only the inverted normals while leaving the rest as is so when I export to stl it has a continuous outer fram and will print properly how can I isolate and flip the inverted normals without it flipping the rest of the model too?
Hello @Kitt_Beesley,
You can flip normals via the Tool> Display Properties> Flip function. This will flip the visible polygons on screen. To isolate polygons, you would use any of the normal ZBrush functions for isolating polygons–chiefly mesh visibility and Polygroups..
