[attach=9713]ZNPgrab.jpg[/attach]
ZNotePad is an easy way to write ZNotes without having to worry about scripting.
It is ideal for those who are writing tutorials or who want to annotate their recorded zscripts
for publishing on ZBC.
- Enter text directly from the keyboard.
- Preview your note at any time.
- Add an image, text color or background color at the click of a button.
- Save all your notes to one text file for easy cut-and-paste into your tutorial.
Full instructions are included in the zip.
***Note: there are two versions, one for US keyboard and one for UK keyboard.
If anyone wants a different keyboard version, send me a message (but remember that ZNotes do not display all special characters).
Edit: NoteMarker
This is a plugin button as suggested by aurick later in this thread.
Pressing the button during a recording will place a short bit of code in the zscript. This can then easily be replaced by a note. Full instructions in the zip. If you’re new to user plugins check out this information .
April 22 2005 : Revision to NoteMarker: now version 04
This is now a bit more elegant. Pressing NoteMarker during recording simply displays a note while adding a placeholder. Press the NoteMarker button after ending the recording to convert each placeholder to a numbered Note which can easily be replaced with a ZNotePad note. If you forget to do this your recording won’t stall (as in previous versions); simply press Notemarker with record OFF to load the file and add notes.
SHIFT-click NoteMarker button for Help.
This version won’t convert recordings made with earlier versions. Instructions in the zip.
