[attach=12584]ZQmaskpic.jpg[/attach]
ZQuickMask is a plugin for anyone who wants to paint their own masks.
- Click the button to enter ‘mask mode’.
- Paint your mask. You can use any alpha or stroke.
- Shift+click the button when you’ve finished to convert to stencil.
The mask is ‘flat’, with no depth info or soft edges: ideal for masking areas of a 2.5D painting before applying color or materials.
Use ZQuickMask to create stencils for use in Projection Master to help texture models.
When using with Projection Master it is best to make the mask/stencil before using Projection Master.
Full instructions in the zip.
I hope you find ZQuickMask useful.
[EDIT:
I’ve revised the plugin slightly, just added a couple of error messages and a small bug fix.
A few points:
- To erase mistakes use the ‘TransMat’ custom material loaded when ZQuickMask is launched. You’ll find it at the bottom of the Materials palette; it looks flat white.
- For basic painting use the ‘MaskMat’ custom material loaded by default (flat black).
- Any tool, alpha, stroke or material can be used with sometimes interesting results.
Adjust lighting and use Best Render for fibers etc.
- To save a stencil for re-use, export the appropriate alpha. When re-using, import the alpha,then load the custom curve from the ZStartUp\ZPlugs\ZMask_data folder before pressing the Alpha>Make Stencil button.
