Hello guys:
Well, after the incredible work of Monstermaker on his Ape, I must to say that I felt really inspiring and wanted to make a gorilla, I use a old mesh that I had of a gorilla I wanted to do.
Finally the release of the work of Monstermaker give me the force to restart mine.
It is a way to say him thank you for all this years of inspiration.
This is only the begining of the work.
Hope you like it.
All the best, Arturo
P.S: Rickhope you don´t mind that I make other ape. Thank you again!!!
this one is awesome. great sculpt really
Hey Arturo.
Long time since I’ve seen something new from you.
Looking cool, reminds me very much of Stan Winston’s Amy.
Look forward to seeing where you take it.
Cheers
Cesar Dacol Jr.
Aka, The Voodoo Monkey
Thank you booth:
Voodoomonkey:
Yes it is true, I´m on set till august.
I made a movie from August to November, and then I began other. This weekend it is the first free weekend in long time. I will have to work the monday and then return to my home, so this weekend out of home is good to make something on Zbrush.
It is true that look like Ami, I have made the sculpture from memory, no refrences, and trying to make a female, so my mind I supouse that mind toke info from the Marvellous sculpture of Miles Teves.
Thank you,
Arturo
Hey Man.
I know how it is.
Work is a blessing and also a curse.
That’s life isn’t it… double edge sword.
Something always has to give.
It’s nice to see you haunting the grounds again.
Cheers
Cesar Dacol Jr.
Super start! Did you start the base mesh in ZB or another program?
TD
It was the human head mesh of Pixolator changed on Maya, and after that, all the modelling and detaills in Zbrush.
Maybe this pix helps.
Thank you,
Arturo
This was before Zbrush massive work.
Hello again:
Here is a render test of the texture.
I would like to share a alpha I have made for the textures of the Gorilla, it is a fast one, but I will try to make a newone spending more time on it.
Thank you,
Arturo
Hmmm, it seems to be monkey-time. Nic head for sure!
Very nice model, and a beautiful start on the detailing. Thanks for showing the skin alpha (it helps to get an idea of how to go about making one.)
DHARMAESTUDIO,
This looks very nice.
I don’t think anyone has a patient on gorillas so you shouldn’t worry about doing one yourself:D
I am looking forward to seeing this one progress. Keep up the good work!
~BW
Hello this is the final result.
Thank you for the coments.
I´m happy with the result but I will try to make ,more changes on the wrinkles between nose and eyebrow.
hope you like it!!
About hair:
One by one on photoshop.
Arturo
P.S: I know it is a lowland gorilla but I couldn´t resist to put MIST on the background
wow, maybe I should work on a gorilla so I can get top row. Exellecent material dude
Well done.
Your time on the hair was worth the effort.
I like that you remembered the color modeling on the lips too
It has it’s own personality as well…
Nice work.
~Brian
Arturo, that really is some fantastic work. From the modeling to the texture, it really is superb. Well done, I give you 5 stars.
very good final DHARMAESTUDIO !
Maybe help see the diferent renders I use to make the image.
Arturo [attach=45763]lady-renders.jpg[/attach]
What I did was mix the diferent parts of the diferent renders, for example the eye of one and the other shadows form other.
After that I made the color of the skin more grey and touch a bit the contrast of the renders.
Hi Arturo, As far as I’m concerned you can never have too many apes. This looks great . Thanks for making a friend for mine.
Thank you Sir:
This is a proud coming from you.
I like much more yours.
Arturo
I made this testto see the texture.
Hope you like it.
I begining to test with a closer shoot to the object, I feel that sometimes give more ilusion of live than show the end of the model(neck).
Hope you like it.
Arturo
