I don’t know how to word this, but when working in polyframe mode with zmodeler, I often find empty panels/space or error in geometry (most likely from me still learning how to use zmodeler effectively) where I would like to be able to fill them, or “copy/paste” new panels or spaces in. I know how to use bridge, close, close holes, and what not to do what should work for these issues, but I find they don’t quite work as I am trying to explain. For example, if I find an empty space between the modified polyframes, how can I fill them exactly as the negative space is shown? Also how can I generate “panels” or geometry in these negative spaces where zmodeler won’t respond. Here is one example in the screen shot below, as you can see the negative square spaces are what I am hoping to replace or generate, square by square or section by section.
Often using beveling, or qmesh combined with other modifiers causes receding in the polyframe creating negative space or “empty artifacts”.
Hope this is somewhat coherent, I have been scouring the web for an answer so I come here.
