File Saving Prob....
I using zbrush 3.1.I having problem with saving the work.When I save mesh as a tool while saving the file crashes and a masseage pops out saying flie saving incomplete but it actually saves the file but when next i reload it as tool zbrush crashes…It happen quit often.and it is so frustrating. you have to make the whole thing again.If someone has solution to it plase post it.egarly waiting…
Please follow this forum’s guidelines when posting any troubleshooting inquiry. With each troubleshooting post, please include your full system specs and any other pertinent information which will allow us to determine if this is one of the following: a) user error? b) Misunderstanding of a specific feature, such as its usage and limitations? c) An item which has already been resolved. d) An item which needs to be resolved.
IMPORTANT: Before posting a troubleshooting item, make sure that:
  1. You are using the latest ZBrush version.
  2. You have a ‘clean’ ZBrush install. i.e. remove any items which you have added (such as older ZScripts and other startup items) which may result in unexpected - and difficult to resolve - problems.
  3. You did not increase the PreferencesMax polygon count or Compact Mem to a level which can not be supported by your system specs.
Any threads that do not follow these guidelines will be closed. Thank you for your cooperation.
